click on a polygon and drop a number in the designated field in sequence
564
10-21-2018 02:27 AM
rao_muhammadimranulhaq
'm looking for a tool out there for sequential auto-numbering... something that uses the edit tool (or something similar) to simply click on a polygon and drop a number in the designated field in sequence, and it would obviously have to be easy to reset as the edit session progresses.
DanPatterson_Retired
sounds pretty specialized and maybe an arcobjects task.
you could have a look at
ArcGIS Code Sharing
but I suspect you will have to implement your own
