Calculate the mean of values in several fields in Field Calculate
7570
02-03-2015 11:43 AM
AaronKing
Lets say i have a feature class or table with 3 fields
[val1], [val2], [val3]
all are floating point fields.
i add a new field
[mean]
and I want to use Field Calculate to get
[mean] = AVERAGE([val1], [val2], [val3])
how do i do that?  I have tried AVERAGE, AVG, MEAN, I have tried looking for help on this. Usually, VBA commands as used in Excel or Access work fine in field calculator, but AVERAGE does not work.
I dont care if its python or VBA, I just need something that works in Field Calculate.
I have no null values in any of the 3 fields I am trying to average.
NOTE: I am NOT trying to find the average of values in a field (vertical) - right clicking the field name and selecting statistics will not do what i need, nor will the Summary Statistics tool.
AnthonyGiles
Honored Contributor
Aaron,
Here is a solution using python, this will account for any null values:
def mean(val1, val2, val3):
  fieldList = [val1, val2, val3]
  validList = []
  for i in fieldList:
    if i != None:
      validList.append(i)
  meanVal = sum(validList)/len(validList)
return meanVal
or if you are sure there is no null values a simple sum([!val1!, !val2!, !val3!])/3 should work
AnthonyGiles
Honored Contributor
Aaron,
  validList = []
  for i in fieldList:
    if i != None:
      validList.append(i)
return meanVal
