Calculate max number of non-overlapping polygons
5030
13
05-13-2017 05:52 AM
JeffThomasILM
There is a proposed ordinance that would allow an activity on a property so long as it is a specified minimum distance (parcel edge to parcel edge) from another property with the activity (let's say 500 ft). I need to figure out the theoretical maximum number of properties that could allow this activity. I have all the eligible parcels selected (which is tens of thousands). I could put a half-distance (250 ft) buffer on every one of them, which of course would result in massive overlap. But if there's a way to strategically eliminate buffers to get maximum coverage with no overlap, that would be exactly what I need! Or is there a better, totally different approach to this? Thank you for any insight!
XanderBakker
Esri Esteemed Contributor
OK, as promised, find below the code that I used:
# Name:        parcel_analysis.py
# Purpose:
# Author:      Xander
# Created:     13-05-2017
import arcpy
def main():
    import os
    arcpy.env.overwriteOutput = True
    fc = r'C:\GeoNet\ParcelAnalysis\data.gdb\Parcels_selected'
    fc_out = r'C:\GeoNet\ParcelAnalysis\data.gdb\Parcels_final_oid17'
    oid_init = 17 # 67  # the OID of the parcel where to start
    buf_size = 150  # distance setting, in my example in meters
    oids = [oid_init]  # list of oids for the selected parcels
    oids_popped = []  # list of excluded parcels
    # for checking the expanded area per iteration
    feats = []
    fc_buf = r'C:\GeoNet\ParcelAnalysis\data.gdb\Parcel_buffers_oid17'
    # create a dictionary with oid vs parcel polygons
    flds = ('OID@', 'SHAPE@')
    dct_pol = {r[0]: r[1] for r in arcpy.da.SearchCursor(fc, flds)}
    # get initial parcel and apply buffer
    pol_init = dct_pol[oid_init]
    buf_init = pol_init.buffer(buf_size)
    feats.append(buf_init)
    # remove parcels that are in the buffer
    dct_pol, dct_next, oids_popped = RemovePolygons(dct_pol, buf_init, buf_size, oids_popped)
    # iterations
    buf_pol = buf_init
    iteration = 0
    while len(dct_next.keys()) > 0:
        iteration += 1
        print " - iteration:", iteration
        # based on buffer area and potential next parcels, select "best" option
        oid_min = GetNextPolgon(dct_next, buf_pol, buf_size)
        if oid_min is None:
            break
        oids.append(oid_min)
        pol_min = dct_next[oid_min]
        # update the buffer polygon including the buffer of the next selected parcel
        buf_pol = UpdateBufferPolygon(buf_pol, pol_min, buf_size)
        feats.append(buf_pol)
        # remove the polygons that are within the expanded buffer
        dct_pol, dct_next, oids_popped = RemovePolygons(dct_pol, buf_pol, buf_size, oids_popped)
    # write the buffers for each step
    arcpy.CopyFeatures_management(feats, fc_buf)
    # create the output final parcels featureclass
    feats_fin = [r[1] for r in arcpy.da.SearchCursor(fc, flds) if r[0] in oids]
    arcpy.CopyFeatures_management(feats_fin, fc_out)
    # print "\n", GetWhere(oids_popped)
    print "\nOID's final parcels:\n", GetWhere(oids)
def GetWhere(oids):
    # print the list of oid's so you can use it in a where clause
    oid_where = ', '.join([str(o) for o in oids])
    oid_where = "({0})".format(oid_where)
    return oid_where
def RemovePolygons(dct, buf_pol, buf_size, oids_popped):
    # remove the polygons that are in the buffer
    # and generate a dict with next parcels to evaluate
    dct_next = {}
    for oid, polygon in dct.items():
        if polygon.distanceTo(buf_pol) <= 0:
            bla = dct.pop(oid)
            oids_popped.append(oid)
        elif polygon.distanceTo(buf_pol) <= buf_size:
            dct_next[oid] = polygon
    return dct, dct_next, oids_popped
def GetNextPolgon(dct, buf_pol, buf_size):
    # get the next parcel based on the smallest increment of the buffer polygon
    min_size = 99999999
    min_oid = None
        pol_i_buf = polygon.buffer(buf_size)
        pol_tmp = pol_i_buf.union(buf_pol)
        if pol_tmp.area < min_size:
            min_oid = oid
            min_size = pol_tmp.area
    return min_oid
def UpdateBufferPolygon(buf_pol, pol_min, buf_size):
    # update the buffer polygon with the next buffered parcel
    buf_add = pol_min.buffer(buf_size)
    new_pol = buf_pol.union(buf_add)
    return new_pol
if __name__ == '__main__':
    main()
I did a few scenarios, starting with different OID's and one should evaluate which starting parcel will get the best result. The red circle indicates the parcel where the iterations started:
curtvprice
This sounds like you really need a Point Distance tool for polygons. (Unfortunately, one does not exist.)
If you're willing to get into arcpy Geometry objects, the DistanceTo operator would allow you to measure that edge-to-edge distance directly. You'd want to first select by an extent envelope (say using the "from" features extent envelope + buffer distance) so you wouldn't have to calculate from-to for 10,000 x 10,000 polygons.
Geometry—Help | ArcGIS Desktop
I think you could successfuly use the resulting data to answer your questions without the extreme processing load of all the buffers and interesects.
JoshuaBixby
MVP Esteemed Contributor
My initial impression is that this problem is more complicated than how it is presented.  To find a true maximum, it is an optimization mathematics problem in addition to a GIS problem.  Given that not every parcel is eligible, and I am guessing that eligible and non-eligible parcels are intermixed at some level, the parcels that get the activity first will drive the final outcome.  If different parcels are chosen first, likely different outcomes.
Instead of trying to find the true/theoretical maximum, which is likely a very challenging problem, would it suffice to find a ballpark or likely/probable outcome?  For the latter, you could run a couple of tens of scenarios where you start seeding the activity randomly across the eligible parcels and then find how many eventually end up fitting within the criteria.
MervynLotter
MVP Regular Contributor
If I understand the problem, then you could also try simply using a negative buffer distance (i.e. -250 m) and only those parcels large enough will have buffer fragments remaining within them.
XanderBakker
I think I'm getting close, although my method might no yield the absolute best possible case. One should probably test with several options and compare the results.
In map below, the green parcels meet the required condition and the blue ones get selected based on the minimum distance between parcels, using a manually selected polygon as the starting point (blue parcel in red circle).
I will post some Python code and explanation tomorrow.
XanderBakker
# Purpose:
# Author:      Xander
import arcpy
def main():
    import os
    feats = []
    # iterations
    buf_pol = buf_init
    iteration = 0
        iteration += 1
        if oid_min is None:
            break
def GetWhere(oids):
    return oid_where
    dct_next = {}
            bla = dct.pop(oid)
    min_size = 99999999
    min_oid = None
            min_oid = oid
    return min_oid
    return new_pol
    main()
JeffThomasILM
Wow, thank you, Xander! I tried it on a sample section of my data and it does exactly what I need! I'm nowhere close to proficient enough with Python to create a script like that. And thank you to everyone on this thread for responding so quickly!
XanderBakker
You're welcome.Could you mark the post that answered your questions as the correct answer?
If you need some more detailed explanation on what is going on in the script, just let me know.
curtvprice
Xander, nice work. I knew it was possible to use this method, but armed with this example when I need to do something like this I'll have some great code to steal from. I'm hoping this nifty polygon to polygon distance example will be helpful to others too!  Vote this guy up!
JoshuaBixby
Xander Bakker‌, nice work addressing the GIS portion of the problem.  Once the GIS portion is addressed, then comes the operations research or optimization portion of the question, i.e., what is the true maximum parcels and what configuration represents that true maximum.
I did some futzing over the weekend.  Since the OP didn't upload any sample data, I decided to use Esri's backyard: City of Redlands Open Data: Open Data Zoning.  To simplify the problem, and to not get into the issue of property records directly, I decided to use Zoning units in the central part of Redlands around Esri's campus.
I made the following assumptions:
  • Parcels/geometries for consideration are Single-Family Residential (sample size - 71)
  • Activity cannot be allowed within 500 ft. of parcel that already allows activity (buffer distance)
  • No restrictions between adjacent Single-Family Residential and other zoning categories (edge condition)
I didn't have time to apply a true optimization model, so I thought it would be interesting to look at some basic simulations.  The general approach:
  1. Randomly select first parcel
    • Add parcel OID to selection list
    • Create spatial selection polygon
  2. Randomly select next parcel
    • Buffer selected parcel 500 ft.
      • if parcel is disjoint with spatial selection polygon:
        • Union parcel with spatial selection polygon
  3. Repeat step 2 until sample size exhausted.
  4. Repeat steps 1 through 3 for x number of simulations
There are likely ways to optimize the compute time of the approach above, but I didn't bother to spend the time since my approach could simulate 1,000 scenarios in a few minutes.
Since 1,000 scenarios ran fairly quick, I just did that and 10,000 scenarios.  For the 1,000 scenario runs I did, I always ended up with 1,000 unique outcomes.  For the 10,000 scenario runs I did, I would typically end up with 9,980 or so unique outcomes.
Looking at one of the 10,000 scenario runs, the outcomes breakdown to:
Number Parcels in Solution/OutcomePrevalence
1020
11100
12442
131164
142104
152533
162139
171098
18335
1943
Looking at the distribution of solutions is interesting in its own right.  It appears the minimum number of parcels that meet the conditions is likely 10.  There might be a 9 solution out there somewhere, but would decisions based on this information change much whether the minimum is 9 or 10?  On the opposite end, the maximum number of parcels that meet the condition is likely 19.  Similar to the minimum, there may be a 20 or 21 solution that exists, but does knowing the true maximum gain much.
Assuming for the sake of discussion that 19 is the maximum number of parcels that meet the conditions, 43 different combinations were found that provide 19 parcels.  Looking just at the prevalence of individual parcels in those 43 combinations:
Looking at the graphic, you can see there are 4 parcels that are in all of the 43 combinations, and 3 of those 4 are adjacent to other zoning categories.  Since there is no penalty for being adjacent to other zoning categories, it makes sense that the higher prevalence parcels are scattered around the boundaries of the block of single-family residential parcels.
Getting back to my original comment to the OP, this is much more than just a GIS question.  Since allowed activities will likely be approved on a first-come-first-approved basis, each time an activity is approved for a given parcel, it influences how many total parcels might be selected in the end.  Looking back at the table of results, there are 20 outcomes that would only allow for 10 parcels to be selected.
