I have a polygon feature class within a file geodatabase that contains parcel information for our utility district. I am working on building some models to update the parcel data from raw data. One of the areas that I am stuck on is with using the Calculate Field tool. One of the fields has (2) attributes (Proxy and Condo). What I am trying to do is to select all rows that have an attribute of "Condo" and copy the PID (Parcel Number) into a new field. Also, to enter the attribute "Condo" into a new field as well. Not sure how to select the PIDs that have the 'Condo' attribute and copy only those records into a new field.
Thank You for the help
