CAD to Geodatabase
1036
01-27-2010 12:51 PM
TedCronin
http://help.esri.com/EN/ArcGISDesktop/9.4/Help/index.htm#/CAD-To-Geodatabase/00120000001Z000000/
In the syntax section, there is a box around [input_cad_datasets,...].  Is this the expected behavior?
input_cad_datasets
The collection of CAD files to convert to geodatabase features.
Input CAD Dataset
TedCronin
TedCronin
The same issue for Transpose Fields:
http://help.esri.com/EN/ArcGISDesktop/9.4/Help/index.htm#/Transpose-Fields/0017000000V4000000/
in_field
[[Field, Value],...]
and farther down
attribute_fields
[attribute_fields,...]
(Optional)
TedCronin
The same issue here:
http://help.esri.com/EN/ArcGISDesktop/9.4/Help/index.htm#/Add-Rasters-To-Mosaic-Dataset/001700000085...
input_path
[input_path,...]
Maybe this is intended, just looks different is all.
