ArcGIS Desktop - Need to set Merge Rules in Spatial Join for 90 fields, is there a way to do this in bulk? Change default merge rule?
3772
02-15-2017 11:35 AM
MalekSraj
I am trying to perform a spatial join that will aggregate about 90 fields using a SUM function.
In the Field Map I get the option to right click on each field and set the merge rule to SUM.
This would be extremely tedious for me to do, especially since I have to perform such a spatial join for 30+ layers.
Is there a way to change the "default" merge rule option to SUM instead of FIRST? How about change the field merge rules in bulk?
Below a screenshot of the fields in spatial join that I'm trying to aggregate, I would need to click through each of these and set the merge rule:
Spatial Join Fieldmaps that need a change in Merge Rules
JayantaPoddar
Have a look at fieldmap.mergeRule parameter in the Python Script in Spatial Join—Help | ArcGIS Desktop
Think Location
JayantaPoddar
Think Location
MalekSraj
Thanks, isn't there a way to do it without ArcPy?
DanPatterson_Retired
The link Jayanta provided is for the spatial join tool in ArcToolbox... why not use it? He was pointing out the options and what they mean.
