ArcGIS crashes using geoprocessing or search windows
1453
12-29-2016 12:04 PM
StaceyMcDaniel
ArcGIS 10.4 is crashing each time the Search Window is opened resulting in an ESRI error report.  It also crashes when any geoprocessing tool dialog is opened.  I've updated the software to 10.5 and the problem has not been resolved.  This is occurring on one user's computer and happens with multiple user log in profiles.  ArcCatalog is also exhibiting the same crashing behavior.
I've tried several suggestions I've found, which I've listed, and nothing has yet resolved the issue.
Tested multiple user profile with same result (user profile works on different computer)
Cleaned out temp folders
Reviewed Python 2.7 install and folder permissions
Reset Internet Explorer to default settings
Turned off Hardware Accelerator
Repair install (10.4)
Uninstall / Reinstall (10.4)
Install Runtime Error patch for 10.4 (resolved this error with ArcCatalog, but not the crashing)
Installed ArcGIS 10.5
Any suggestions would be appreciated.
Thank you,
Stacey
MichaelVolz
Esteemed Contributor
What Windows operating system did you install the GIS software onto?
StaceyMcDaniel
The software is running on a Windows 7 Professional with SP1 machine.
