See this similar discussion:http://forums.arcgis.com/threads/54102-Spatial-join-tool-vs.-right-click-spatial-join-producing-different-results?p=185943#post185943<SNIP>One workaround (if you want to continue using Spatial Join) would be to uncheck 'Keep All Target Features' parameter on tool dialog or use 'KEEP_COMMON' option in script.
See this similar discussion:http://forums.arcgis.com/threads/54102-Spatial-join-tool-vs.-right-click-spatial-join-producing-different-results?p=185943#post185943I have confirmed that we introduced a bug in 10 Sp4. Really sorry about that! The problem will be fixed in 10 SP5.Just FYI (according to my colleague):The tool works fine if all input points find spatialy related polygons (i.e. Join_Count > 0). The problem happens when a point is encountered without any related (e.g., INTERSECT) join features, all subsequenct records in the output gets null values from the join features. One workaround (if you want to continue using Spatial Join) would be to uncheck 'Keep All Target Features' parameter on tool dialog or use 'KEEP_COMMON' option in script.
This happens with the default field mapping.
Any other suggestions to get this to work?
I cannot calculate the proper length of the polylines and copying to another feature class within the gdb does not fix it. Only thing that works is an export and re-import to/from a shapefile.
First: we are working hard on a special patch on 10 SP4 to fix the problems. Hope it will come out soon.
Second: Copy Features tool worked for my test data. I reproduced the wrong shape_length (for the target lines) and then run Copy Features to gdb output. The output shape_length values reflect the original/input line lengths. Will you be able to share your data so I can try?
The attached Toolbox contains a model that may be helpful in working around this issue until the bug is resolved. It has proved helpful for some customers.
Can you confirm there will be a targetted patch pre-SP5? Any idea on due-date?Cheers,Mike.
Signed in members can post, follow updates, and more. New here? Register a free account.
