Alter Field does not alter the field when changing case in field name
3466
10-25-2017 11:04 AM
BrandonFlessner
I am trying to use the Alter Field geoprocessing tool to change a field name of a feature glass in a geodatabase. I'm trying to change the field from Total_Mdollars to Total_MDollars. The tool completes "successfully" but the field name remains unchanged. Anyone else having this issue? I think its a bug. The field contains values but according to the docs this should not matter when changing the field name.  I've tried it in Pro, ArcMap 10.5.1, and via Python.
Asrujit_SenGupta
BrandonFlessner
Thanks Asrujit, I'm glad to know that I wasn't making a silly mistake. Interesting to know that it has existed since 10.2.1 and has not been fixed in 3.5 years!!  #jack dangermond
RebeccaStrauch__GISP
Trying to rename a file or folder even in windows explorer will have issues and not change.  A work around of course is to change it two times.  Something like
   Total_Mdollars to Total_MDollars1  then
   Total_Mdollars1 to Total_MDollars
Not ideal, but at least workable.
