Addresses of private dam owners
2244
11-25-2014 06:56 AM
ChrisScott2
Hello, I am working on a project where I am looking to find the addresses of private dam owners in the region. I currently have the feature class showing the location of all the private dams. What is the best way to retrieve the addresses associate with each dam? Any help would be appreciated. Thank you.
Zeke
Regular Contributor III
Do you want the dam address or the owner address or the parcel address of the dam? They could all be different. If you can get parcel data, that typically has the parcel address and the owner address. If the dam is addressed separately, that should be in the dam layer. If not, you may want to check with your state/province regulatory body (DEQ in Michigan), or possibly a county drain commission, if one exists.
ChrisScott2
I am looking for private land owners with private dams on their property. So I believe I would need to use the parcel data to find their addresses.
Thank you.
