Add Join requires OID field for join - bug #NIM038601
3298
08-25-2011 12:22 PM
ToddColes
I am having issues using Add Join to join to a table that doesn't have an OID field.  The bug has been reported as fixed, so I was wondering is anyone else having this issue?
ChrisSnyder
Honored Contributor
Don't know about the bug (or the bug fix), but as a work around, simply making a copy of the table using one of the ESRI tools such as CopyRows or TableToTable would auto create an OBJECTID field in output table.
Kathleen_Crombez
I am running into this same issue.
DanPatterson_Retired
Did you try the workaround?
