Write to Snowflake database from Portal web app?
2447
12-13-2022 06:44 AM
SBark_CBRE
Is it possible to edit data in your Portal and this change is reflected on the Snowflake database? i.e. write to the database.
I've read comments that imply you can read and query data, but nothing and editing back to Snowflake database - as you can with a Postgres. I just wanted to confirm this?
Enterprise v10.9.1 // Pro 3.0
MelissaJarman
For the ArcGIS Enterprise 10.9.1 version, you can only publish Snowflake data from ArcGIS Pro as a map image layer. Editing data in Snowflake is not on the near term horizon, but there are plans to provide support for query only feature services for Snowflake data in an upcoming release.
Here is a blog that may be helpful!
https://www.esri.com/arcgis-blog/products/arcgis-pro/data-management/introducing-cloud-data-warehous...
