WHERE have they gone: Tools for SDE 9.3 and ArcMap 10
2099
6
08-25-2016 01:58 PM
AmyRose
Hello,
I have started a new job that still uses SDE 9.3 and ArcGIS 10.  I am having trouble finding tools that will work on those versions because most links I find reference the now defunct ArcScripts.
Any help?
Tools of interest for this version of ArcGIS are Geodatabase Diagrammer, X-Ray and anything else of help.  Is there a repository of tools/scripts for the older versions of SDE and ArcGIS?
Thanks in advance,
Amy Rose
Robert_LeClair
Esri Esteemed Contributor
AmyRose
Robert,
Thanks so much.  The appsforms site looks promising!  I have been to the other sites but couldn't find older versions to download.
Again Thank you,
Amy
JayantaPoddar
Hi Amy,
Please check if the following works with ArcGIS 10.
X-Ray for ArcMap
X-Ray for ArcCatalog
GeoDatabase Diagrammer for 10X
You can further search, browse, and use code, scripts, models, add-ins, widgets, and more using ArcGIS Code Sharing.
Think Location
AmyRose
Thanks Jayanta,
I tried to install X-Ray but got an error:
I guess there is a difference between 10.0 and 10.1.
I did install the GeoDatabase Diagrammer, but it gives errors when I run it.  One error says my Visio Trust Center settings are not set correctly.  I changed the Trust Center settings but I still get the error.
It looks like I will be documenting our GIS model the old fashion way!  Luckily, there are plans to upgrade to newer versions of sde and ArcGIS....
Thank you again,
Amy
Robert_LeClair
There was a GeoNet thread about this:  https://community.esri.com/thread/56713  Not sure if it will help but a known issue.
AmyRose
In case anyone else has the issue with GeoDatabase Diagrammer running with errors:
I have ArcCatalog 10.0 and Visio 2013
I changed the Trust Center Macro settings to "Enable all macros" and Trust access to the VBA project object model checked.
This did not stop the errors.
I then went to the File Block settings and uncheked all the boxes.
Then the GeoDatabase Diagrammer started working.
I left Macro settings as I had changed them.
Hope this is helpful to someone,
Amy
