Upgraded Oracle 19c eGDB from 11.1 to 11.4 using ArcGIS Pro 3.4 - Invalid Indexes / dbms_utility.compile_schema
498
04-09-2025 04:33 AM
JamesMorrison1
Hello Everyone
On our TEST system we upgraded Oracle 19c eGDB from 11.1 to 11.4 using ArcGIS Pro 3.4
After the upgrade we got a number of Invalid Indexes
SELECT * FROM DBA_OBJECTS WHERE STATUS!= 'VALID' ORDER BY OWNER, OBJECT_TYPE, OBJECT_NAME;
OWNER             OBJECT_NAME           OBJECT_TYPE STATUS
MYDATA            A3992_IX1                      INDEX INVALID
MYDATA            A3993_IX1                     INDEX INVALID
MYDATA           A3994_IX1                     INDEX INVALID
MYDATA           V_PRINT_JOBS              VIEW INVALID
I did find this information:
  • DBA_OBJECTS is mostly for PL/SQL objects (procedures, views, etc.).
  • Indexes can show up there, but they don’t require “compilation.”
  • An index reported as invalid usually means it’s UNUSABLE or LOGGING anomalies — not that it’s corrupt.
However, the following query returned no rows
SELECT owner, index_name, status, tablespace_name FROM dba_indexes WHERE status = 'UNUSABLE';
So I ran:
EXEC dbms_utility.compile_schema( 'MYDATA', compile_all => FALSE );
No Rows Returned
Which seemed to fix the issue - I just do not understand why  dbms_utility.compile_schema would fix Indexes. Anyone help?
AlisonWieckowicz
I believe it works because a spatial index is a function based index.  dbms_utility.compile_schema doesn't directly handle indexes, but it can indirectly impact them if the code defining the indexes (like function-based indexes) is invalid.
AlisonWieckowicz
