This version of Geodatabase is either invalid or out of date Error
2491
05-03-2020 01:14 PM
RedaAli
 I have upgraded the DB from oracle 11.2.0.1 to 11.2.0.4.
 the GDB version  is 10.1
How can I get the Compatability of Oracle releases with ArcSDE 10.1
and is it compatabile?
can I enable  a new updated  version of Enterprise geodatabase, I have License of 10.7.1
George_Thompson
Esri Notable Contributor
If you are using ArcMap 10.7.x, then  it may not be compatible; Client and geodatabase compatibility—ArcGIS Help | Documentation
If you are trying to upgrade to 10.7.x, I would recommend installing ArcMap 10.5.1 then upgrade the Oracle EGDB. Once that is completed and verified, I would use the 10.7.x client to upgrade to that version.
The "oldest" supported version is currently 10.3.x; Esri Support ArcMap 10.8
--- George T.
George_Thompson
--- George T.
