We have tables appearing within ArcGIS Pro, SDE connection that no longer exist within the SQL Server connection.
Deleting the tables while in ArcGIS Pro removes them, but when we refresh the connection they are still there.
I suspect there was an issue when copying up these large tables and they were deleted from the SQL Server connection, but left registered in SDE.
Is there any way we can clear those tables from SDE?
The SQL Server is an AWS RDS and we might getting some mirroring causing the problem.
