ArcGIS Pro 2.9.5; Oracle 18c 10.7.1 EGDB
(will be upgraded to Pro 3.3.5; Oracle 19c 11.3 EGDB soon)
Background:
I have inherited an unregistered database view (non-spatial). The view has some joins.
select
--cast(rownum as number(38,0)) as rownum_,
cast(rownum as int) as rownum_,
sn.rdsec,
sn.ownership,
sn.name,
sn.from_,
sn.to_,
sn.boundary_rd,
sn.boundary_juris,
sn.sort,
sn.surf_mater,
sn.surf_width,
sn.shold_type,
sn.shold_width,
sn.row_,
sn.desrow,
sn.platw,
sn.environ,
sn.fenviron,
sn.tcyear1,
sn.tcaadt,
sn.aspd,
sn.replac_surf_width,
sn.class_op_grouped,
sn.recon_activity,
sde.st_length(sn.shape) as road_length,
rs.length_assumed_only,
sde.st_length(sn.shape) - rs.length_assumed_only as length_vs_assumed,
sn.numb_lanes,
sn.lane_km,
sn.strad_wavg,
sn.surface_condition_wavg,
sn.surf_year,
sn.base_year,
sn.gran_year,
sn.surf_age,
sn.base_age,
sn.gran_age,
sn.det_model_constr_type,
sn.next_forecast_activity,
sn.next_forecast_activity_descr,
sn.next_forecat_year,
sn.last_forecast_activity,
sn.last_forecast_activity_descr,
sn.last_forecat_year,
arw.replacement_cost
from
infrastr.strln_svw sn
left join
infrastr.ar_road_vw arw
on
sn.rdsec = arw.inventory_asset_id
left join
infrastr.am_excluded_roads_sd er
on
sn.rdsec = er.rdsec
left join
select
rdsec,
sum(evt_to - evt_from) as length_assumed_only
from
infrastr.road_assm_status
where
assm_status = 'A'
group by
rdsec
) rs
on
sn.rdsec = rs.rdsec
where
er.rdsec is null
and (sn.aspd <> 'UNIMPROVED' or sn.aspd is null)
and rs.length_assumed_only is not null
Regarding casting ROWNUM as an integer:
ArcGIS Pro is treating the ROWNUM_ column as a double:
So ROWNUM_ can't be used as the unique ID when dragging the view from Contents to the map:
However, if I were to cast ROWNUM as a number(38,0), then ArcGIS Pro would treat it as a long integer, which is good:
Question:
Why does Pro treat cast(rownum as int) as a double?
