Oracle 19 upgrade and old connection files
1433
01-03-2023 04:44 PM
Labels (2)
forestknutsen1
MVP Alum
We have upgraded a dev database for Oracle 12c to Oracle 19. We did this by creating a new pluggable database and using the data pump to migrate the data over. Then we give the new database the original database's TNS name and rename the old database. All of our existing connection files appear to be working fine. Is there any need to recreate them?
Also, I noticed that this still appears to be an issue at ArcGIS 10.6
https://support.esri.com/en/technical-article/000011653
MarceloMarques
@forestknutsen1 - if ArcGIS is not changing, then there is no need to recreate the connection files
A. once you are using TNSNAMES as you pointed out then you will not need to edit any of the geodatabase connection files and they will work just fine to connect to the geodatabases on the new oracle server as you mentioned yourself, hence there is no need to recreate any of the geodatabase connection files.
or
(B) and (C) below apply if using Easy Connect Syntax and not using TNSNAMES in the geodatabase connection files
B. create new geodatabase connection files that point to the geodatabases on the new oracle server
or
C. make a copy of the old geodatabase connection files and manually edit each one of them to point to the geodatabases on the new oracle server
Note: if using ArcGIS Server and there are services published that connect to the geodatabases in the Oracle Server with Easy Connect Syntax, then those service will break and will need to be republished, now if you used TNSNAMES to publish the ArcGIS Server services then everything will continue to work as expected as well.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
Yes, it is a good practice to recreate the geodatabase connection files with the new version of ArcCatalog or the new version of ArcGIS Pro that you are now using, especially if the geodatabase connection files were created with a very old version of ArcGIS.
forestknutsen1
MVP Alum
Okay, thanks. But in this case just the Oracle version will be changing not the version of ArcGIS.
MarceloMarques
or
or
forestknutsen1
MVP Alum
Thanks! Everything is setup with TNSNAMES.
