Oracle 11g-Parcel deleted but still appearing in Geoprocessing results
1158
06-19-2023 11:59 AM
Thales
@MarceloMarques and community,
I have deleted a parcel from geodatabase, but when i ran my custom geoprocessing tool this parcel is been picked up as if it there, even from history is not available it gone, i have reconciled and posted the job also. I am using oracle 11g with Arcmap 10.8.1 what could be problem. Am asking if there is any method besides compressing geodatabse to make sure that this cache is deleted.
MarceloMarques
@Thales, if you are working with geodatabase versioning then make sure you reconciled and posted the correct child version that you made the edits to the sde.default version. You can also use a connection file that points to a version where you made edits and use that connection file in geoprocessing tools.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
VaibhavS
You could check if there are any orphan feature classes in the geodatabase.
GDB_Items
SDE_TABLE_REGISTRY
SDE_COLUMN_REGISTRY
SDE_LAYERS
SDE_GEOMETRY_COLUMNS
GDB_ITEMRELATIONSHIPS (if the feature class existed in a feature dataset)
VaibhavS
MarceloMarques
