Options Other than Built-in Replica
1538
02-19-2024 08:24 AM
CodyPatterson
MVP Regular Contributor
Hey all,
I've just received the unfortunate news that after days of work to enable versioning and create replicas of all of our datasets, our other GIS software 3GIS does not support versioning and we will need to turn it off to continue our work.
I was curious if anyone has been in this situation before? Transactional replication from SQL to SQL was not pulling all information over and could not be used in feature layers as Subtype codes and other ArcPro features were unusable.
At this point I'm looking for other methods to get this data across without the Create Replica tool, and without versioning enabled, definitely in a pickle.
Thanks in advance!
MarceloMarques
@CodyPatterson - If you decide to go with your own ETL process, then that is something that needs to be build using the ETL Tools that I described, your data model and your data is unique to you, therefore you will need to choose the ETL Tool that you are more comfortable with or ask some ETL expert to help you automate the process, you can also reach out to Esri Professional Services for assistance if you want Esri to help you with the ETL process.
* ETL stands for Extract, Transform and Load
ETL Process ToolsSQL Server T-SQL, SQL Server Integration Services, ArcGIS Model Builder, Python Arcpy, ArcGIS Data Interoperability Extension, Safe Software FME Workbench / FME Server.
SQL Server Always-On Replication is a feature of SQL Server, you can read more details in the link below about connections from ArcGIS.
Connections to highly available SQL Server databases—ArcGIS Pro | Documentation
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
@CodyPatterson - If you cannot use ArcSDE Geodatabase Replication with the Geodatabase Traditional Versioning for any reason, then you can use SQL Server Always-On Replication or you can build your own ETL process to synchronize the data via, SQL Server T-SQL, SQL Server Integration Services, ArcGIS Model Builder, Python Arcpy, ArcGIS Data Interoperability Extension, Safe Software FME Workbench / FME Server. I hope this helps.
CodyPatterson
Hey @MarceloMarques
Thank you for the suggestions, I'll have to check out the Always-On Replication, when we attempted the transactional it had some issues importing over the Feature Class info and I was unable to use any geoprocessing tools on the data itself. I was curious if you had any documentation or pointers to previous posters who have created a tool such as the one you mentioned?
Thank you!
Cody
MarceloMarques
I hope this helps.
CodyPatterson
Hey @MarceloMarques
I think that answers my questions, thank you for the information!
Cody
