New DB server, Oracle 19c, Failed to connect to the specified DBMS instance
3147
08-31-2023 06:56 AM
MagalyClément-Zaber
Our actual configuration is :
  • Arcgis Enterprise 10.8.1
  • Oracle 12c
We want to test the connection with a new version of Oracle : Oracle 19c.
The server is installed and connexion with "sql manager" works fine.
On my local machine, i have installed Oracle Client 19.
I want to create a geodatabase.
I modified the tsname.ora to put the new config:
SIGIMGPROD19C =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCP)(HOST = MYSERVER)(PORT = 1521))
(CONNECT_DATA =
(SERVICE_NAME = MYINSTANCE)
The connection test with tnsping works fine.
But when I use the tool "Create Enterprise Geodatabase", I've got an error :
Failed to connect to the specified DBMS instance (Échec d'accès au serveur DBMS)
I use a batch to execute arccatlog to use specific path :
Set PATH=C:\oracle\product\19c\cli19c32\client_1\bin;C:\Program Files (x86)\ArcGIS\Desktop10.8\bin
START ArcCatalog.exe
I there something I forgot to configure ?
Thanks for help
Tags (1)
MarceloMarques
First test the connection to the Oracle database using Oracle SQL Plus.
This will help determine if Oracle Instant Client is configured correctly.
Oracle Instant Client requires the Microsoft C++ Redistributable Library.
Look the Oracle Instant Client Installation documentation.
See my communuity.esri.com white paper.
How to Install the Oracle Database Client for ArcGIS?
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
I hope this helps.
MagalyClément-Zaber
Thanks a lot ! This helps me.
lsnrctl status  show me the error in tnsname.ora !
The service name was not complete, I have forgotten the complete DNS name.
MarceloMarques
Glad to assist.
