Need to install ArcSDE 10.3 on windows
1624
12-27-2021 08:01 AM
santhoshT
I need to install the open-source ArcSDE 10.3 on windows.
Could you please share the steps to follow?
ABishop
santhoshT
I don't find the installation ArcSDE 10.3 package on the mentioned link. Can u pls advise?
George_Thompson
Esri Notable Contributor
As Amanda mentioned, there is NO install for ArcSDE 10.3 or newer version.
Those files have been replaced with built-in functionality in the ArcGIS clients / Python / Toolboxes.
What are you needing from the ArcSDE install?
--- George T.
santhoshT
1) I used the below code to the SDE 10.3 direct connection  from java
String instance = "1234";//sde port
String server="host";
if (conn == null) {
try {
conn = new SeConnection(server, instance, database, userName, password);
System.out.println("Connection Successful");
I got the below error
[java.lang.UnsatisfiedLinkError: no sdejavautil in java.library.path] with root cause
I have to install the ArcSDE 10.3 on my local machine so that I can able to avoid this issue.
