I have a current SDE using SQL 2008 R2. I want to migrate my current SDE to a new SDE. The new SDE has a different schema. Is there a way I can keep the instance name and database name?
Hey James - can you clarify what you're hoping to do? Are you moving your geodatabase to a new SQL Server instance, or are you hoping to move all your data from one geodatabase to another geodatabase in the same SQL Server instance? OR do you just want the data to be owned by a different user/schema, but remain in the same geodatabase?
