Lost Domain info during Merge
1755
12-08-2022 11:46 AM
KeyesWilliamson
Hi all,
Situation:
I work in cultural resources. I used Collector to capture data in the field. The template I used included domains for various info (like if I was documenting a walkway, a materials field would have a domain drop down with values for concrete, brick, wood, etc). I have 14 different categories (vegetation, buildings, roads, etc) that each have p/l/p data.
I need to gather all the multiple points, lines, and polygons data into three combined datasets (one each for p/l/p). I then need to add new fields and reexport.
Problem:
When I merge all the point feature classes the new output does not preserve the domain values...just the number like 2, 4, 5, which correspond to concrete, brick, wood, etc).
Question:
How do I keep the domains intact and properly populated in the new output?
I hope that all makes sense.
I am using ArcGIS Pro.
Tags (3)
KeyesWilliamson
Following up with screenshots.Settings for merge 1.JPGSettings for merge.JPGData to Merge.JPG
MarceloMarques
Check if the output geodatabase featureclass field has the domain and if the domain is assigned to the field.
You can export the geodatabase schema to xml (schema only, no data) then import the xml into a new geodatabase to create an empty geodatabase schema that has the domains, and has the domains assigned to the fields, then you can use the data append tool to load (merge) the data from multiple sources into the empty geodatabase schema.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
Steve_Salas
Comparing the output from ArcGIS Desktop 10.8.2 and Pro 3.1.3, I found this same issue with the domains... PLUS... Pro seems to retain the default value setting of the input fields, where ArcGIS Desktop did not.  When one of the input feature classes does not have that particular field, instead of the corresponding output polygon remaining Null (as with Desktop) for that field, the Pro merge changes that record to the default value.
