How to convert PostGIS geom type to ST_geom?
2168
11-21-2019 09:29 AM
MarieCline_Delgado
Is there a way to convert the PostGIS geom type to the ST_geom type when using a trigger in PostgreSQL that will insert data from a PostGIS database table into an ESRI database table?
George_Thompson
Esri Notable Contributor
The easiest way would be to copy the PostGIS geometry feature class back into the geodatabase and use the default geometry storage (ST_Geometry).
You could identify the new records within the PG table and append them to the ST table via Python/ArcPy or look into the ST_Geometry commands available: ST_Geometry—Help | ArcGIS Desktop . The latter may require a few different steps.
Is this the direction that you are looking for?
--- George T.
