Failed to connect to the specified DBMS instance
4613
8
08-01-2021 03:28 PM
Amjad_Bahati
Hello, Dear All
I have a problem with a database connection, when I am trying to connect to oracle database, I face the below-attached error.
Please let me know if you have any idea
Many thanks.
DavinWalker2
Hi Amjad,
Hopefully this ESRI Technical Article can assist.
John_Spence
That error message looks like it is missing some information and/or letters.
Amjad_Bahati
Just as a reminder, I'm only  faced  with ArcGISPro 2.8
I've solved with ArcMap 10.7 by download Oracle Instant Client "instantclient_11_2" and placed on drive C then named it under environment variables under path as C:\instantclient_11_2 and it works.
MichaelVolz
Esteemed Contributor
You would need a 64-bit Instant Client for Pro whereas ArcMap uses the 32-bit Instant Client.
Amjad_Bahati
Dear All
I tried to use many solutions to fix this issue... I instilled 64- bit client for ArcPro I reinstalled ArcPro but I got an unknown error !! it is different from the previous error please see in below picture
George_Thompson
Esri Notable Contributor
Did you put the 64 bit client before the 32 bit client in the PATH variable?
Are you using TNSNAMES or EZConnect for the instance field?
--- George T.
Amjad_Bahati
yes, I've put it 64 before ...
I am using TNSNAMES ..
George_Thompson
Did you configure the TNSNAMES for the instant client following this article?
https://support.esri.com/en/technical-article/000011850
--- George T.
