I am receiving an error when trying to create an Enterprise Geodatabase or when creating a database user on Oracle 19c using ArcGIS Pro 2.6.3 or ArcMap 10.7.1, 10.8 or 10.8.1.
Please, see the attachment.
Ok, thanks for that additional information.You may need to create the database (shell) in a container
A new option starting with Oracle 12c, called Multitenant Architecture, consisting of a container database that can hold many pluggable databases, is supported at the pluggable database level. ArcGIS supports the same functionality in pluggable databases as is supported for Oracle 11g R2.https://desktop.arcgis.com/en/system-requirements/latest/database-requirements-oracle.htm
Can you try that and report back?
Hi @George_Thompson, The problem was not related with being or not a container.
They created the db in their environment. I think that was something wrong that I did in configuring Oracle in my environment to test.
Can you provide some more information:
Any other information that you can provide on the Oracle side would be useful. Thanks!
Hello George.
In the parameters I entered the instance and db info, sys password and sde password to create sde user. I have provided the keycodes file too.
The instance already have the database created.
I can connect to the database with the info provided to the tool with sys user.
George,
On the Oracle side, I just installed and created the database with sys and system users enabled.
The database is not container.
I will try and report back.
I contacted the Oracle support and we solved this issue of create enterprise geodatabase.
Thank you a lot for the help.
Was the issue related to the DB not being a container?
Appreciate the update.
