Hi Sebastian,Q) What OS are you using for your ArcSDE geodatabase on PostgreSQL?If it's Red Hat Linux (RHEL) 5 or SUSE 10, please review this KnowledgeBase Article:Hope this helps,
It's Windows Server 2008, so that doesn't help, I'm afraid.
Hi Sebastian,Please review this KnowledgeBase Article:KB #29585 - Error: Bad Login UserHope this helps,
- your network has both ipv4 and ipv6 addresses and you need a entry for both
I fought with this for hours. In the end the only thing that worked for me was to comment out both ipv4 and v6 and just open the gate completely:
host all all all md5
I note there is a discrepancy in syntax between Postgres and Esri docs for ipv6 that may come in to play. Compare the suffixes, "%10/n" vs "/n":
[Esri] To allow any machines with an address beginning with fe60 to connect, you would add this line to the pg_hba.conf file:
host all all fe60::0000:0000:0000:0000%10/8 md5
[Postgres] An IPv6 address range might look like ::1/128 for a single host (in this case the IPv6 loopback address) or fe80::7a31:c1ff:0000:0000/96 for a small network.
::1/128
Matt,
not sure what you mean by comment out the entries for ipv4 and ipv6 completely?Do the settings below work?
- first row for ipv4
- second for ipv6
this is opening ipv4 and ipv6 wide open....
md5
Kasia
