Did arcpy.Copy_management change from 10.4 to 10.7?
658
11-14-2019 12:38 PM
DarylHochhalter
Running the following gives 2 different results if run from server Standard 10.7 machine or Desktop Advanced 10.4 machine.
Where CODGEO_Datasets and Offline_Datasets are lists of full path strings.
Where some feature class in the dataset has attachments
# Process: Copy CODGEO Datasets
for i, val in enumerate(CODGEO_Datasets):
   arcpy.Copy_management(CODGEO_Datasets, Offline_Datasets, "Feature Dataset")
Run from Desktop 10.4 I get this inside my Offline FGDB
Offline_Dataset (containing all the feature classes)
some_feature_class_ATTACH
some_feature_class_ATTACHREL
Run from Server 10.7 I get this inside my Offline FGDB
Offline_Dataset_ATTACH
Offline_Dataset_ATTACHREL
So instead of the attachment table & relationship class having the name of the feature class that has attachments as when run from Desktop 10.4 machine, when the same script is run on the Server 10.7 machine, the attachment table and relationship class have the name of the Dataset.
So is this expected behavior? Do we now enable attachments on datasets not the feature class inside the dataset?
