Can someone please tell me why create role doesn't work?
2419
07-29-2016 06:01 AM
MikeSullivan
So I have a Local Government Model schema SDE geodatabase and every time I try to use the "Create Role" data management tool, I get an Underlying DBMS error.  The geodatabase is stored in SQL Server 2008 R2 SP 3.  I've attached the error message to this thread.  Someone please tell me why this is happening.  I don't want to have to use SQL Management Studio to add roles to DBs, but I will if ESRI's tool doesn't work.
Please help.
George_Thompson
Esri Notable Contributor
Does the user that is running the tool have permission to create a role in SQL Server?
Which user is creating the role, geodatabase admin or another user?
Privileges for geodatabases in SQL Server—Help | ArcGIS for Desktop
--- George T.
BirajaNayak
This looks like known issue.
BUG-000093032 : ‘Create Role’ tool fails with ‘Error Creating Role’ error for SQL Server geodatabases at 10.4
NIM102049: Unable to revoke database roles from SQL Server 2012 users using the Create Role geoprocessing tool or arcpy.CreateRole_management.
What is the ArcGIS Desktop Version you are using.
MikeSullivan
Version 10.4.1.  So it appears it's a bug then and yes, I have adminstrative rights to the database.  Thanks.
