Can I add/delete fields from a versioned table?
1865
07-27-2017 07:36 AM
TheodoreRakel
I'm using ArcGIS 10.2.1.  For some reason, I had it in my head that I needed to unversion a table in order to add or delete or change the size of fields in a versioned table.  Then I had to version the table again after making the changes.  Is that necessary?
Tags (1)
ChristopherMcClain
It is not necessary to unversion a GDB before making the changes you indicated.  However, make sure you are making the changes as the database owner.
ChristopherMcClain
Asrujit_SenGupta
Only one thing to change in the answer above....it should be data owner and not database owner..
