Hello everyone,
Environment ArcSDE 10.4.
We are contemplating the option to remove all versions for a SDE database, compress, unversion layers, and then version to fix a problem we are having with versioning trees.
If we make a copy of the current SDE database with all versions in a backup/copy. Then we remove all versions, compress and unversion, and version back with only Default in the main SDE database. Is there a way to copy back a few versions from the backup to the main SDE.
The main question is to know if there is a way to copy a specific version from one SDE database to another SDE database. Knowing that both SDE databases have the same schema.
It could be also the case of restoring a specific version from a backup.
