Add additional "attributes" to ST_GEOMETRY *object* column
652
07-12-2022 02:23 PM
Bud
Esteemed Contributor
Oracle 18c SDE.ST_GEOMETRY EGDB:
Has anyone ever tried adding additional "attributes" to an ST_GEOMETRY object column?
Such as adding an SDO_GEOMETRY attribute to the object column:
ENTITY
NUMBER(38)
NUMPTS
NUMBER(38)
MINX
FLOAT(64)
MINY
FLOAT(64)
MAXX
FLOAT(64)
MAXY
FLOAT(64)
MINZ
FLOAT(64)
MAXZ
FLOAT(64)
MINM
FLOAT(64)
MAXM
FLOAT(64)
AREA
FLOAT(64)
LEN
FLOAT(64)
SRID
NUMBER(38)
POINTS
BLOB
SDO_GEOM
SDO_GEOMETRY
Source: ST_Geometry in Oracle
Or, alternatively, add an additional "subtype" to the object supertype.
Sure, it wouldn't be supported. But that's not what I'm asking about. I'm asking if anyone has tried it.
Reason: I want to use Oracle Spatial linear referencing functionality, but can't switch my FCs from ST_GEOMETRY over to SDO_GOMETRY. We can't add additional geometry columns to a FC (causes errors). And I want to avoid creating dozens of helper SDO_GEOMETRY FCs if I can help it.
Thanks.
