Searching Location and Features Portal for ArcGIS Not Returning Searches of Numbers
720
08-30-2017 01:29 PM
Heath_Birchfield
I have a  web map on Portal for ArcGIS 10.5.1, and have the search function enabled for my map. The attribute I have it set up to search from is a string field that contains numerical codes (ex. 10-555-235). However, upon trying to search for those locations the search widget within Portal does not return anything, even if I type the code in it's entirety (ex. 10-55-235), type only a portion (ex. 555), or even if I change the search settings in the web map details (i.e. contains/equals). Is there a limitation on the search functionality of Portal that prevents it from handling this kind of search? Can it not effectively search and return numerical attributes?
All help and suggestion is appreciated.
Cheers!
Heath_Birchfield
A few things I forgot to note:
  • This issue is only experience on one layer, other layers search fine.
  • The layer that is exhibiting the issue has a spatial join applied
