Issues in Utility network validate topology
2861
8
12-07-2018 04:35 AM
SurajJha1
I have created a utility network. Published it and added it to map. But while validating my network topolgy Getting error "Dataset must be versioned". I checked the dataset(through which utility network service has been published) it is branch versioned. Please help to resolve this issue.
SurajJha1
Solved the issue. This was actually my mistake I was not enabling version management during publishing of service.
Thanks
SilviaRyter
In addition to the Branch Versioning Type, you must register the dataset as versioned before you publish the service
Example for register as versioned
SurajJha1
Even after that i am getting this issue. If you could send the exact steps it might help
SilviaRyter
For me, switching to branch versioning doesn't always work properly either. Sometimes I have to repeat this step several times.
So I recommend you
  • Return to traditional versioning type
  • Restart ArcGIS Pro
  • Change back to Branch Versioning
  • After right-click the feature dataset that contains the utility network and click under Manage, Register as Versioned
  • Enable Network Topology
  • After this step you should already know if it work
  • afterwards publish or overwrite your Service
SurajJha1
Thanks for your promp response. Tried but not worked.
SilviaRyter
are you validation your network in the Client-Server connection mode? You still get the message "Dataset must be versioned"?
SurajJha1
Adding UN from layer not from sde. Please correct if I am wrong
SurajJha1
Thanks
MattDeitemeyer
Thanks for following through on the solution. I made the exact same 'mistake' trying to stand up a Trace Network in PRO 3.1.
