Apply Asset Package errors with "OID-based relationships must use same width of object ID"
1277
01-04-2026 03:07 PM
EdwardBlair
Hi -
So, I added to a UPDM asset package an annotation class that has a relationship as follows:
Origin class:  PipelineJunction
Origin Primary Key: OBJECTID (ObjectID)
Destination class:  SVT_Order_Anno
Destination Foreign Key: FeatureID (Long)
Running "Apply Asset Package" results in the error in the subject (when I remove the relationship the GP tool works without error).
I *thought* an ObjectID had a data type of "Long" - but apparently not.    Any suggestions on how to resolve this would be much appreciated.
Thx,
Ed
VenkataKondepati
Honored Contributor
You can’t use OBJECTID for this, even though it looks like a Long.
In Utility Network / UPDM asset packages, relationships cannot use OBJECTID as the primary key. While OBJECTID is internally stored as a 32-bit integer, it is system-managed, non-stable, and not a true user key, so the asset package validator rejects it.
How to fix it:
Add a user-managed Long or GlobalID field on PipelineJunction
Populate it (or use GlobalID / GUID)
Point SVT_Order_Anno.FeatureID to that field instead
Re-run Apply Asset Package
OBJECTID may be numeric, but it’s not valid for relationship classes in asset packages. Use a stable user field (preferably GlobalID).
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
VenkataKondepati
Honored Contributor
How to fix it:
Regards,
Venkat
EdwardBlair
Ok.  Thanks.  Will give the GlobalID a try.   Fingers crossed.
Ed
EdwardBlair
Worked as described.  Thanks!
Also found that anno expressions don't seems to work in JScript -- but they do in Arcade, so am going to make life simple(r) and stick with Arcade.
Ed
RobertKrisher
@EdwardBlair you'll want to migration the feature linked annotation class to use global ids.
