Apply an asset package error message
9976
20
02-20-2018 09:30 AM
deleted-user-GKyg-xriCvci
Hello, I am struggling with creating en electric utility network inside my organization. I followed steps from documentation: Get started with the Electric Distribution Utility Network Configuration—Get Started | ArcGIS for El... and everything is configured as it should be. I am using PostgreSQL 9.5.7 database. My problem starts in the point 4.. I managed to 'Stage the Utility Network' but every time I am trying to 'Apply an asset package' I am getting errors. I have tried different configurations already but usually the error is:
Running script AssetPackageToUtilityNetwork...
ArcGIS Pro 2.1.1.10257
untools 2.1.0.1
Updating schema on ElectricDistributionAssembly
Updating schema on ElectricDistributionDevice
Updating schema on ElectricDistributionJunction
Updating schema on ElectricDistributionLine
 ERROR 999999: Error executing function.
The subtype already exists. [un.andreasbv.ElectricDistributionAssembly]
Failed to execute (AddSubtype).
EXCEPTION
 File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\common\wrappers.py", line 90, in wrapper
 return func(*args, **kwargs)
 File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\gptools\tools.py", line 300, in run
 share.schema_apply()
 File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\utils\shared_validation.py", line 504, in schema_apply
 return self.apply()
 File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\utils\shared_validation.py", line 450, in apply
 result = func(**kwargs)
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 16618, in AddSubtype
 raise e
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 16615, in AddSubtype
 retval = convertArcObjectToPythonObject(gp.AddSubtype_management(*gp_fixargs((in_table, subtype_code, subtype_description), True)))
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
 return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Error executing function.
 Failed to execute (AssetPackageToUtilityNetwork).
As an Asset Package I am using default geodatabase ElectricDistribution_AssetPackage.gdb, I am checking both Structure and ElectricDistribution and as Input I am using Utility Network created in previous step. I am not loading data as for a now I would like to have just a scheme.
Could anyone tell me what am I doing wrong? I believe there is some detail which stands behind the logic of Utility Network Model but as documentation describe the process quite briefly I can't figure out appropriate approach.
MikeMillerGIS
Esri Frequent Contributor
Could you share the entire message? What version of pro/untools?
ChatruNenavath
Hi Michael,
Here is the entire message.
"Messages
Start Time: Tuesday, August 27, 2019 1:37:04 PM
ArcGIS Pro 2.4.19948
untools 2.4.1
Executing from ArcGIS Pro, 3 map(s), activeMap = True
Parallel processing enabled: 3
Asset Package schema version: 2.4
2019-08-27 18:31:59 Starting 3 processes for Append
2019-08-27 18:36:22 Starting StructureJunction...
2019-08-27 18:36:22 Finished StructureJunction (0:03:59)...
2019-08-27 18:37:37 Starting ElectricDevice...
2019-08-27 18:37:37 Finished ElectricDevice (0:05:15)...
2019-08-27 18:39:13 Starting ElectricJunction...
2019-08-27 18:39:13 Finished ElectricJunction (0:02:35)...
2019-08-27 18:39:40 Starting ElectricAssembly...
2019-08-27 18:39:40 Finished ElectricAssembly (0:01:47)...
2019-08-27 18:40:07 Starting ElectricDeviceUnit...
2019-08-27 18:40:07 Finished ElectricDeviceUnit (0:00:15)...
2019-08-27 18:40:40 Starting ElectricJunctionA...
2019-08-27 18:40:40 Finished ElectricJunctionA (0:00:20)...
2019-08-27 18:40:52 Starting StructureBoundary...
2019-08-27 18:40:52 Finished StructureBoundary (0:01:27)...
2019-08-27 18:41:19 Starting ElectricLineA...
2019-08-27 18:41:19 Finished ElectricLineA (0:00:25)...
2019-08-27 18:41:28 Starting ElectricWireData...
2019-08-27 18:41:28 Finished ElectricWireData (0:00:20)...
2019-08-27 18:41:37 Starting ElectricLine...
2019-08-27 18:41:37 Finished ElectricLine (0:09:15)...
2019-08-27 18:51:37 Starting 3 processes for ImportAssociations
2019-08-27 18:53:58 Starting Associations_001...
2019-08-27 18:53:58 Start Time: Tuesday, August 27, 2019 6:52:29 PM
ERROR 001896: Invalid association parameters (row 2). A requested row object could not be located. .
Failed to execute (ImportAssociations).
Failed at Tuesday, August 27, 2019 6:52:41 PM (Elapsed Time: 11.77 seconds)
2019-08-27 18:53:58 Starting Associations_003...
Failed at Tuesday, August 27, 2019 6:52:41 PM (Elapsed Time: 11.73 seconds)
2019-08-27 18:53:58 Starting Associations_002...
Failed at Tuesday, August 27, 2019 6:52:41 PM (Elapsed Time: 11.75 seconds)
Failed at Tuesday, August 27, 2019 6:54:01 PM (Elapsed Time: 5 hours 16 minutes 56 seconds)".
MikeMillerGIS
If you look at the feature classes, can you verify the features where appended?
You can try the import association again, you will need to modify the AP_workspace folder that was created. In there, open the main.py and remove calls prior to the import associations call. Using the python command prompt, run that by file.
HeatherWillever
Hello, I am trying to just view the Sewer Utility Network.  I want to check out the functionality of trace and learn how to find problems with the network and see if it would be useful to my clients.  I followed the steps to create a utility network, and got a similar error as above.  I don't want to add any of my data, just view what came with the package but it hangs up on the apply asset package.  Is there a more detailed step by step instructions to just create a network and see how it works?  I am using Pro 2.5.1.  I have no maps open, I downloaded the lates UNTools.  This is the error I keep getting.
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (ImportXMLWorkspaceDocument).
Am I missing something?  Does this only work in an Enterprise environment?  The documentation said it could work with a File Geodatabase.
Any help would be greatly appreciated.
PaulLeBlanc1
Hi Heather,
Can you confirm which version of untools you have (it should be printed at the top of the GP messages)?
The Utility Network works on file geodatabase. You can use Asset Package to File Geodatabase—Tool Reference | ArcGIS Solutions to quickly get started.
HeatherWillever
UNtools Version 2.5.1.  I also tried the asset package to file geodatabase, with the same error.  Thanks for the quick response.
PaulLeBlanc1
Hmm that is odd. What version of sewer are you using? You can open the _Version table in the asset package and paste the contents here.
HeatherWillever
Schema Version  2.4
Pro Version  2.5
untools Version  2.5.1
Date Exported  3/24/2020
Model Version  3.1
Model Date  3/24/2020
PaulLeBlanc1
I was successful in loading Sewer 3.1 with Pro 2.5.1 and untools 2.5.1
If you can, upgrade your Pro and try that. If it's still failing, then you should probably reach out to support. I'm not sure what might be causing this error...
HeatherWillever
I made sure everything was upgraded and it still seems to get hung up on the ImportXMLWorkspaceDocument, any clue why that may be happening?
Running script AssetPackageToFileGeodatabase...
ArcGIS Pro 2.5.1.22081
untools 2.5.1
Executing from ArcGIS Pro, 3 map(s), activeMap = False
Parallel processing enabled: 6
and refer to the error help for potential solutions or workarounds. Failed to execute (ImportXMLWorkspaceDocument).
Failed to execute (AssetPackageToFileGeodatabase)
