Flutter Build Error
6666
12-10-2024 02:07 PM
Labels (2)
vijaybadugu
I installed
Flutter version 3.24.5 on channel stable at C:\dev\flutter
 Dart version 3.5.4
 DevTools version 2.37.3
I just downloaded the code for just displaying map
When I run from VS code IDE, I am getting below error.
Warrning: SDK processing. This version only understands SDK XML versions up to 3 but an SDK XML file of version 4 was encountered. This can happen if you use versions of Android Studio and the command-line tools that were released at different times.
FAILURE: Build failed with an exception.
* What went wrong:
Could not determine the dependencies of task ':arcgis_maps:compileDebugKotlin'.
> Unknown Kotlin JVM target: 21
JenMerritt
Hi there,
Please see this recently published blog post:
https://community.esri.com/t5/arcgis-maps-sdks-native-blog/solution-android-studio-ladybug-2024-2-1-...
This should resolve the issue you're seeing, assuming you have Android Studio Ladybug installed.
JenMerritt
Hi there,
vijaybadugu
Thanks. it is working after switch to 17
JenMerritt
No problem, thanks for confirming 👍
