Is there a way to get more detail on error?
1473
02-08-2011 01:14 AM
Chee_ChonThum
I used the API to try to open my geodatabase, and the OpenGeodatabase() function return -1. I tried it on the sample gdb in the API and the function succeeded.
Is there any way to get more detail on why the function failed? A description of the last error will be helpful.
LanceShipman
At this point there is no way to get more detail on an error. Beta 2 will document many of the error codes. We are looking at ways to provide more detailed error messages.
Is the geodatabase you are trying to open a pre-10.x file geodatabase? The API only supports 10.x file geodatabases.
Chee_ChonThum
Yes, I was trying to open a 9.3 geodatabase. Will there be any support for pre-10 geodatabase in the future?
LanceShipman
The File Geodatabase API leverages the work done in ArcGIS 10 to simplify the Geodatabase system tables. Because of this there are no plans to support pre-10.0 versions of the File Geodatabase.
Before final we will return a more descriptive code when an attempt is made to open a pre10.0 Geodatabase. -1 is not particularly helpful.
BobCave
I am curious...why are you using return codes instead of throwing exceptions?
Cheers,
Bob
