Is it possible to convert a ShapeBuffer object to a SqlGeometry?
5243
04-21-2016 07:28 AM
EddieHedges
So far I've been able to write some somewhat complex code create WKT representations of sql geometry objects, but it's somewhat hacky and was hoping that their would be a way to use the FileGDB API to easily convert ShapeBuffer objects to SqlGeometry objects.
Any help would be appeciated.
Tags (1)
LanceShipman
There is no way in the File Geodatabase API to convert a Shape buffer to a SQLGeometry.
EddieHedges
lshipman-esristaff
Any way to get an update on this?
LanceShipman
DonnyVelazquez
You can use Ogr2ogr to do the conversion.
MSSQLSpatial - Microsoft SQL Server Spatial Database
