File GDB API 1.5 Release
21016
22
03-07-2017 07:24 AM
LanceShipman
1 22 21K
The File Geodatabase API 1.5 is now available for download from GitHub https://github.com/Esri/file-geodatabase-api/tree/master/FileGDB_API_1.5. The FileGDB 1.5 release is primarily a maintenance release with the addition of  a few new compilers and platforms.
What’s new at 1.5:
    • MS Visual Studio 2015 support.
    • Allow the use of the Spatial Reference ID to create the spatial reference (BUG-000100781)
    • Support for new operating system versions:
Linux:
     Red Hat
     SUSE Linux Enterprise Server
     Ubuntu
Windows:
     Windows 8.1
     Windows 10.0
MacOS
     Yosemite (10.10)
     El Capitan (10.11)
     Sierra (10.12)
Released under the Apache license.
Fixed Issues:
BUG-000100782 File Geodatabase: COUNT(0) should return 0 with a WHERE clause that returns no rows (1=0).
BUG-000100783 Remove Windows FileGDBAPI.dll's reliance on Microsoft.VC90.CRT.
BUG-000088293 FileGDB API throws -2147217395 error when executing SQL query with SQL functions.
BUG-000097116 Table::FreeWriteLock does not clear the lock.
22 Comments
BryanBaker
The link to the 1.5 version above returns "Not found". I believe the correct link is file-geodatabase-api/FileGDB_API_1.5 at master · Esri/file-geodatabase-api · GitHub .
LanceShipman
Corrected the link in the blog post. Thank you Bryan for pointing this out.
PaulAustin1
Any chance you could update the .h files so that they don't define EXT_FILEGDB_API if it is already defined? Adding the first and last lines in bold below does the trick.
#ifndef EXT_FILEGDB_API
#  ifndef EXPORT_FILEGDB_API
#   if defined __linux__ || defined __APPLE__
#    define EXT_FILEGDB_API
#   else
#    define EXT_FILEGDB_API _declspec(dllimport)
#   endif
#  else
#    define EXT_FILEGDB_API __attribute__((visibility("default")))
#   else
#    define EXT_FILEGDB_API _declspec(dllexport)
#   endif
#  endif
#endif
Also I notice the copyright information in the header files is not the same license (Apache 2) as the zip packages that contain the header files on github.com.
NicholasReseburg1
do you have any instructions for n00bz on how to get this running in ubuntu?  I followed the readme in the API and "making" just resulted in a bunch of errors like
../../lib/libFileGDBAPI.so: undefined reference to `_wtoi64(wchar_t const*)'
../../lib/libFileGDBAPI.so: undefined reference to `CLSID_FIDSet'
LeoRuss
Hello,
I am new to this forum and to Esri framework.
We need to generate a Geodatabase file within a Java application.
I downloaded the FileGDB_API-64 archive (we are on Linux) and have been trying to build samples for quite some time. Initially, it would not build because of a compiler error - had gcc 7. Tried different versions. 4.0 was too old, 7 - too new. Finally tried with 5.5, and the variable declaration errors went away.
Now, I am getting the following:
/usr/bin/ld: warning: libfgdbunixrtl.so, needed by ../../lib/libFileGDBAPI.so, not found (try using -rpath or -rpath-li
nk)
/usr/bin/ld: ./GeodatabaseManagement.o: undefined reference to symbol '_ZNSt8ios_base4InitD1Ev@@GLIBCXX_3.4'
The warning is not legitimate - the library is where the compiler is looking for it. But the error appears to be an internal deficiency.
Can anybody provide some guidance/advice on how I can create a Geodatabase file (file on the file system, not database) within a Java application?
Thank you in advance.
LanceShipman
Have they tried the 1.5.1 release?
Lance
LeoRuss
Yes, we have. And could not find functionality that would create
Geodatabase file.
LanceShipman
To create a geodatabase see
FileGDB_API\samples\GeodatabaseManagement\GeodatabaseManagement.cpp
// Create a new geodatabase in the current directory.
fgdbError hr;
wstring errorText;
Geodatabase geodatabase;
if ((hr = CreateGeodatabase(L"../GeodatabaseManagement/GdbManagement.gdb", geodatabase)) != S_OK)
wcout << "An error occurred while creating the geodatabase." << endl;
ErrorInfo::GetErrorDescription(hr, errorText);
wcout << errorText << "(" << hr << ")." << endl;
return -1;
This is a C++ example. We don't have a Java interface.
LeoRuss
Hi Lance,
Thank you very much for your help!
I did look at that code, using JNI is an option.
Two questions:
1. It creates Geodatabase file but does not show how to populate it with
data
2. It does not build (under Linux):
make
g++ -fPIC -O3 -m64 -W -fexceptions -D_CONSOLE -DUNICODE -D_UNICODE -DUNIX
-D_REENTRANT -DFILEGDB_API -D__USE_FILE_OFFSET64 -DUNIX_FILEGDB_API -D_FI
LE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -m64
-L../../lib -o ../bin/GeodatabaseManagement ./GeodatabaseManagement.o
-lFileGDBAPI
/usr/bin/ld: cannot find -lFileGDBAPI
collect2: error: ld returned 1 exit status
Makefile:27: recipe for target '../bin/GeodatabaseManagement' failed
make: *** Error 1
Again, I appreciate your help.
LanceShipman
FileGDB_API\samples\ShapeBuffer\ShapeBuffer.cpp provides examples of reading and writing geometries.
FileGDB_API\samples\Editing\Editing.cpp provides examples of editing existing data and search.
LeoRuss
Great!
Except that build fails with the same error:
make
LE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -c
ShapeBuffer.cpp
LE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -m64 -L
../../lib -o ../bin/ShapeBuffer ./ShapeBuffer.o -lFileGDBAPI
Makefile:27: recipe for target '../bin/ShapeBuffer' failed
make: *** Error 1
LanceShipman
The undefined symbol '_ZNSt8ios_base4InitD1Ev@@GLIBCXX_3.4' was reported by several people. They got this when using gcc instead of g++ as their C++ compiler so your CC/CXX vars should either be unset or set to:
CC=gcc
CXX=g++
This would be the ideal setup if we were recommending one:
OS: Ubuntu 18.04
File GDB API Package: https://github.com/Esri/file-geodatabase-api/blob/master/FileGDB_API_1.5/FileGDB_API_1_5_64gcc51.tar...
Compiler: GCC 7.3.0
Steps:
• Run ‘which g++’ and ‘g++ --version’ to make sure you’re picking up the right compiler.
• Unpack FileGDB_API_1_5_64gcc51.tar.gz from your $HOME so $HOME/FileGDB_API-64gcc51 is created.
• cd to $HOME/FileGDB_API-64gcc51/lib and add that folder to your LD_LIBRARY_PATH
$ cd $HOME/FileGDB_API-64gcc51/lib
$ export LD_LIBRARY_PATH=${PWD}:${LD_LIBRARY_PATH}
• Go to the sample folder and build it:
$ cd $HOME/FileGDB_API-64gcc51/samples/GeodatabaseManagement
$ make clean all
rm -f -v ./GeodatabaseManagement.o ../bin/GeodatabaseManagement
g++ -fPIC -O3 -m64 -W -fexceptions -D_CONSOLE -DUNICODE -D_UNICODE -DUNIX -D_REENTRANT -DFILEGDB_API -D__USE_FILE_OFFSET64 -DUNIX_FILEGDB_API -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -c GeodatabaseManagement.cpp
g++ -fPIC -O3 -m64 -W -fexceptions -D_CONSOLE -DUNICODE -D_UNICODE -DUNIX -D_REENTRANT -DFILEGDB_API -D__USE_FILE_OFFSET64 -DUNIX_FILEGDB_API -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -m64 -L../../lib -o ../bin/GeodatabaseManagement ./GeodatabaseManagement.o –lFileGDBAPI
• Run it:
$ cd ../bin/
$ ./GeodatabaseManagement
The geodatabase has been created.
The geodatabase has been opened.
The geodatabase has been deleted.
LeoRuss
Bless your heart!!!
Will get to it first thing in the morning.
LeoRuss
Hello Lance,
Thank you for your help again.
But my issue is different (see complete output below), the error is
/usr/bin/ld:
#Building from top level (samples) dir)
FileGDB_API-64gcc/lib$ export LD_LIBRARY_PATH=$:$
lruss@lruss:/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/lib$
ls
libfgdbunixrtl.a libfgdbunixrtl.dylib libFileGDBAPI.dylib
cd ../samples
lruss@lruss:/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples$
make clean all
make -C Display clean
make[1]: Entering directory
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Display'
rm -f -v ./Display.o ../bin/Display
make[1]: Leaving directory
make -C Domains clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Domains'
rm -f -v ./Domains.o ../bin/Domains
removed './Domains.o'
make -C Editing clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Editing'
rm -f -v ./Editing.o ../bin/Editing
make -C ExecutingSQL clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/ExecutingSQL'
rm -f -v ./ExecutingSQL.o ../bin/ExecutingSQL
make -C FeatureDatasets clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/FeatureDatasets'
rm -f -v ./FeatureDatasets.o ../bin/FeatureDatasets
make -C GeodatabaseManagement clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/GeodatabaseManagement'
make -C Querying clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Querying'
rm -f -v ./Querying.o ../bin/Querying
make -C ShapeBuffer clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/ShapeBuffer'
rm -f -v ./ShapeBuffer.o ../bin/ShapeBuffer
make -C TableSchema clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/TableSchema'
rm -f -v ./TableSchema.o ../bin/TableSchema
make -C TableSchemaXML clean
'/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/TableSchemaXML'
rm -f -v ./TableSchemaXML.o ../bin/TableSchemaXML
make -C Domains
Domains.cpp
-L"../../lib" -o ../bin/Domains ./Domains.o -lFileGDBAPI
Makefile:31: recipe for target '../bin/Domains' failed
make[1]: *** Error 1
Makefile:27: recipe for target 'Domains' failed
make: *** Error 2
Building from samples/GeodatabaseManagement directory
GeodatabaseManagement$ make clean all
-lFileGDBAPI
Makefile:29: recipe for target '../bin/GeodatabaseManagement' failed
make: *** Error 1
LanceShipman
Can you supply us with:
  1. The OS version/distribution (i.e. RHEL, SLES, Ubuntu, etc.) that you are using.
  2. Compiler and version (gcc --version)
  3. Full terminal session from a clean terminal showing how the environment was setup and full build output.
LeoRuss
FileGDB_API-64gcc/samples/GeodatabaseManagement$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.1 LTS
Release: 18.04
Codename: bionic
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/7/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu
7.3.0-27ubuntu1~18.04'
--with-bugurl=file:///usr/share/doc/gcc-7/README.Bugs
--enable-languages=c,ada,c+,go,brig,d,fortran,objc,obj-c+ --prefix=/usr
--with-gcc-major-version-only --program-suffix=-7
--program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id
--libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
--libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu
--enable-libstdcxx-debug --enable-libstdcxx-time=yes
--with-default-libstdcxx-abi=new --enable-gnu-unique-object
--disable-vtable-verify --enable-libmpx --enable-plugin
--enable-default-pie --with-system-zlib --with-target-system-zlib
--enable-objc-gc=auto --enable-multiarch --disable-werror
--with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32
--enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none
--without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu
--host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 7.3.0 (Ubuntu 7.3.0-27ubuntu1~18.04)
g++ -v
COLLECT_GCC=/usr/bin/g++-7
Thread model: posix
Terminal settings/output:
LeoRuss
Apparently, there is message size limit so Terminal settings/output: part got truncated. Here it comes:
FileGDB_API-64gcc/lib$ export LD_LIBRARY_PATH=${PWD}:${LD_LIBRARY_PATH}
FileGDB_API-64gcc/lib$ cd ../samples
FileGDB_API-64gcc/samples$ make clean all
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Display'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Display'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Domains'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Domains'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Editing'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Editing'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/ExecutingSQL'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/ExecutingSQL'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/FeatureDatasets'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/FeatureDatasets'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/GeodatabaseManagement'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/GeodatabaseManagement'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Querying'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/Querying'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/ShapeBuffer'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/ShapeBuffer'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/TableSchema'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/TableSchema'
make[1]: Entering directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/TableSchemaXML'
make[1]: Leaving directory '/mnt/2GB_HD/ALAMON/Software/FileGDB_API_1_5_VS2015/FileGDB_API-64gcc/samples/TableSchemaXML'
make -C Domains
g++ -fPIC -O3 -m64 -W -fexceptions -D_CONSOLE -DUNICODE -D_UNICODE -DUNIX -D_REENTRANT -DFILEGDB_API -D__USE_FILE_OFFSET64 -DUNIX_FILEGDB_API -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -c Domains.cpp
g++ -fPIC -O3 -m64 -W -fexceptions -D_CONSOLE -DUNICODE -D_UNICODE -DUNIX -D_REENTRANT -DFILEGDB_API -D__USE_FILE_OFFSET64 -DUNIX_FILEGDB_API -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -m64 -L"../../lib" -o ../bin/Domains ./Domains.o -lFileGDBAPI
make[1]: *** [../bin/Domains] Error 1
make: *** [Domains] Error 2
LanceShipman
It looks like you are using the MacOS version of the API. Use:
We need to go to better names at 1.6.
LeoRuss
Great, it did build!
I am also looking at runtime samples, I have GIS Runtime Server installed
but I can't find any instructions on how to run/use it.
The GeodatabaseSyncTask syncTask = new
GeodatabaseSyncTask(featureServiceURL);
call in GenerateGeodatabaseSample class
(com.esri.samples.featurelayers.generate_geodatabase package) requires
String featureServiceURL parameter.
I can assume this is the URL of something running/residing on that runtime
server but I can't find any details on how to use it.
Again, thank you for your help!
StevePeaslee1
Lance, has anyone developed a Python wrapper for ESRI's FileGDBAPI.dll?
I've experimented with the open source version of FileGDB dll available through the OGR library in Python and was able to successfully read and export object metadata in XML format from the GDB_Items table.
However I also need to be able to write metadata changes back to the GDB_Items table which requires the ESRI version of the DLL.
DonnyVelazquez
So its been 6 years since the last update. I'm assuming File Geodatabase API has been abandoned.
AJR
There is a build on github for VS2019, but that seems to be the latest.  Is there a plan for when the VS2022 build will be released?
https://github.com/Esri/file-geodatabase-api/tree/master/FileGDB_API_1.5.2
About the Author
Esri for 31+ years. Product Engineer for File Geodatabase, SQLite, Shapefiles
