2001 - Digital Cities (ESRI) on VHS
I still have one of these original tapes on my office shelf Year 2001 - Digital Cities (ESRI) on VHS
ArcIMS 3 Frequently asked questions
ArcIMS 3 Frequently asked questions https://content.esri.com/support/documentation/ims_/faq_final.pdf Step 2: Planning an ArcIMS site configuration https://help.arcgis.com/en/arcims/9.3/install_guide/arcims_windows_install_guide/Installing_ArcIMS.htm#Step_2_site_configuration.htm Configuring WMS connector for IIS with…
The iomega 100 MB Zip Drive - When all your GIS data could fit on a single 100 MB disk
The iomega 100 MB Zip Drive or maybe the 250 MB one
September 18, 2007: DoD Permanently Discontinues Procurement Of Global Positioning System Selective Availability
IMMEDIATE RELEASE No. 1126-07 September 18, 2007 DoD Permanently Discontinues Procurement Of Global Positioning System Selective Availability The Department of Defense announced today that it intends to stop procuring Global Positioning System (GPS) satellites with the capability to intentionally degrade the accuracy of…
NATO phonetic alphabet, codes and signals
The ability to communicate and make yourself understood can make a difference in life-threatening situations – imagine for example that you are trying to alert a search and rescue helicopter of the position of a downed pilot. https://www.nato.int/cps/en/natohq/news_150391.htm
Beginning of GIS for me back in 1988
"GIS" circa 1988
USGS Revision and Product Generation Software (RevPG) Reference: May 07, 1999
Reference: May 07, 1999 USGS Revision and Product Generation Software (RevPG) The U.S. Geological Survey (UsGS) developed revision and product generation (RevPG) software for updating digital line graph (DLG) data and producing maps from such data. Note the system requirements: UNIX Operating Systems 28 Megabytes of RAM 21…
December 31, 1997 ArcInfo Librarian Coverage Layer of COGO parcel polygons converted to AutoCAD and maintain true curves
December 31, 1997 Here's the procedures we used with ArcInfo Librarian Layer of parcels converted to AutoCAD and maintain true curves. This used ArcInfo Workstation v6.1.1/6.1.2/7 running on IBM's AIX v3.5 unix operating system, FTP, and AutoCAD Map 2.0 and AutoCAD R13 on Windows NT. Reference: topic 2.10.0 Arc/Info -…
Example of an early WebGIS Publishing Workflow
(see attached pdf for more detail)
Example of a Production GIS Map Layer Process
Arc/Info Workstation 7.1 on AIX and GPS Basics using a Trimble backpack unit - November 1997
Feature layer customization
Is it possible to group feature layers of a map in arc gis experience builder? say i have roads, railways and I want to group them into infrastructure where the infrastructure will have a dropdown menu with listed features.
Remember - Voice Query Language (VQL™)
Field Survey Work with ArcGIS with Voice Technology 2005 ESRI® GIS Partner Solutions and Services for the Transportation Industry
Where to See Some of the World’s Oldest and Most Interesting Maps
The Unlikely History of the Origins of Modern Maps
Original mobile GIS editing
Original GPS backpack $50,000 each In Depth Tutorials and Information What-when-how: GLOBAL POSITIONING SYSTEM (GPS) -
Is your snapping working today?
Try using one of these digitizing boards to input everything, The Kurta 12" x 12" digitizing tablet, And the Calcomp 44" x 60" digitazing board digitize kurta calcomp
The "Delete Key"
How to use the Delete Key
Printing problem? Try Using A Blueprint Machine
You think you have printing problems? Try using this Ammonia-powered Blueprint Machine for a several hours each day. How to use a Blueprint Machine
Lettering with a Leroy Lettering Set
* Lettering with a Leroy Lettering Set * The Museum of Forgotten Art Supplies
Banyan VINES was a network operating system developed by Banyan Systems for computers running AT&T's UNIX System V
Remember this? VINES is an acronym for Virtual Integrated NEtwork Service. Like Novell NetWare, VINES's network services were based on the archetypical Xerox XNS stack. James Allchin, who later worked as Group Vice President for Platforms at Microsoft until his retirement on January 30, 2007, was the chief architect of…
Quarterdeck Expanded Memory Manager (QEMM)
Remember this? Quarterdeck Expanded Memory Manager (QEMM) is a memory manager produced by Quarterdeck Office Systems in the late 1980s through late 1990s. It was the most popular third-party memory manager for the MS-DOS and other DOS operating systems. Memory management[edit] Main article: DOS memory managementDOS was…
coordinates?
Now that you have decided on you projection/coordinate system, Some basic math with have you up and running ArcSDE x-y scale = x-y resolution = precision x-y tolerance does it fit in 32-bit hardware limitation? x-offset y-offset grid size some cov2sde, shp2sdeand, aml and csh/ksh-shell scripting yeah! puts the "My ArcMap…
Topology basics
Topology basics
Researchers digitize writing with cheap, touch-sensitive paper
This brings back memories: (New) Researchers digitize writing with cheap, touch-sensitive paper (Old) How To: Register a coverage for digitizing in Workstation ArcInfo How To: Register a paper map in ArcMap Apple's original tablet
