Is there a way to stop the draw tool of the Select widget from any other custom widget?
407
08-09-2025 05:51 AM
Vara_PrasadM_S
Hi Team,
In our ExpBuilder App, we are using OOTB Select widget. Its draw tool to select features is on even when the Select widget is closed. Is there a way to stop the draw tool when the Select widget is closed or from any other custom widget through code dynamically?
Any inputs would be really helpful.
Thanks & Regards
Vara Prasad
JeffreyThompson2
MVP Frequent Contributor
In the latest version of Experience Builder (1.18), placing the Select Widget in a Widget Controller and closing it will automatically deactivate the drawing tool.
GIS Developer
City of Arlington, Texas
Vara_PrasadM_S
Thank you for your reply @JeffreyThompson2. Is there a way to achieve this in ExpBuilder 1.15 version?
Can we have it customized by any of following approaches? or any other simple approach?
1. Adding a message action and sending message to deactivate the draw tool from other custom widget
2. Adding a hook to identify the widget's state and deactivate it
Please suggest. Thanks.
JeffreyThompson2
https://community.esri.com/t5/experience-builder-tips-and-tricks/modifying-esri-widgets-and-making-t...
To add this behavior in 1.15, you will need to make a copy of the Select Widget and make your modifications in your copied version.
All Widgets have a props.state property that changes when a Widget is opened or closed. You can build your modifications off of watching this property.
https://developers.arcgis.com/experience-builder/api-reference/jimu-core/WidgetState/
GIS Developer
