Future Breaking Change: JavaScript SDK Widgets Are Being Removed
2833
7
03-24-2025 06:28 AM
JeffreyThompson2
MVP Frequent Contributor
5 7 2,833
Major breaking change alert. The JavaScript API team is going to start removing API widgets in 2026. If your Experience Builder widgets call in any API widgets they will start to break. If you are building any EXB Widgets that use API Widgets now, you should be using Components.
7 Comments
Contributors
About the Author
A frequently confused rock-hound that writes ugly, but usually functional code.
