Unable to complete YPN Survey123
2121
8
12-15-2021 11:16 AM
jamesw
New Contributor III
Hello!
I was trying to submit the Survey123 form to request to join the Young Professionals Network, but I am getting the same "You cannot submit records to the survey since you are not field worker or the survey owner." error described by other posts here.
I tried viewing the survey while not logged in to my account, but it had the same result. Is there any current workaround / alternate method for requesting membership?
Thank you,
James
jamesw
New Contributor III
Hello Hoon,
I had luck going through the Esri Young Professionals Network LinkedIn page. It sounds like the survey is still not working exactly as intended -- I'd suggest reaching out there instead.
Good luck!
Jeong_HoonKim
New Contributor II
Hello, James!
I have the same issue as you. I am curious whether you solve the issue. I appreciate it if you share the updates.
Thank you,
Hoon
jamesw
New Contributor III
Hello Hoon,
Good luck!
Jeong_HoonKim
New Contributor II
Hello, James!
I joined the YPN via LinkedIn group as well. Thank you so much for sharing!
jamesw
New Contributor III
Glad to hear it!
MargaretM
New Contributor III
The Survey is still not allowing submissions.
Jeong_HoonKim
New Contributor II
Hello Margaret!
I reached out to the Esri Support Team and they are waiting for a response from the relevant team.
I will update the status if I can get some useful information.
Thank you!
WesleySmith
I also am unable to sign up as of 3/3/22. Does anyone know if this has been resolved?
Jeong_HoonKim
New Contributor II
Hello, Wesley!
Actually, I communicated on the YPN issue with Esri, but their answer was my role in the organization should be 'field worker' or 'survey owner'. I tried to change my role as those roles in my personal account, but I could not do it since I am the only administrator in my personal account.
During the time I had waited their reply on the issue, I was able to join the YPN via the LinkedIn group. I would recommend you to join the YPN via the LinkedIn group with the following link. You might be able to get a reply from the group within 5 days.
https://www.linkedin.com/groups/6972150/
