Raster Layer: Appearance Enhancement group not working
750
04-06-2021 02:59 AM
JoanaWiese
New Contributor II
Dear all,
I am following the ESRI Academy web course 'Displaying Raster Data in ArcGIS' and I am currently at exercise: Compare band combinations where I am suppoosed to use the enhancement tools to change brightness, contrast and gamma vlaue of my satellite image.
Unfortunately, these tools are not displayed and I am unable to use them. I've noticed that when opening other projects where I use raster data, the tools are also not available (sceenshot attached).
I am using ArcGIS Pro 2.7.1 on a Windows machine.
I have not found any solution online and hope that someone here could help me out or knows what the problem is.
Thank you in advance.
Joana
JoanaWiese
New Contributor II
Hi Suzanne,
Thank you for your reply.
The problem has solved itself. I am not able to actually see and use the enhancement tools in the exercise. Maybe there was a setting that was blocking the tools.
Thanks for looking into it though.
Best wishes,
Joana
Suzanne-Boden
Hi Joana, can you confirm you are taking the ArcGIS Pro 2.7 version of the course? There are multiple course versions available.
JoanaWiese
New Contributor II
Hi Suzanne-Boden,
Yes, I am taking the version for ArcGIS Pro 2.7.
I am mostly confused why the enhacement tool is also not availabe when I open any of my other projects.
Best,
Joana
Suzanne-Boden
Hi Joana, apologies for the delayed response. Our team (and myself) have tested the exercises and can't replicate your issue. The course requires a Standard or Advanced license of ArcGIS Pro. Could you confirm you have the supported license?
JoanaWiese
New Contributor II
Hi Suzanne,
Best wishes,
Joana
