There are many different kinds of rasters that can be used in ArcMap. To better describe and explain these different kinds of rasters, Esri has created help documentation on technical specifications and supported raster formats. Included in the documentation is the ESRI GRID format. This is a very flexible format that many users are comfortable using to process and display data. There is a unique aspect to this format that many users are unaware of that is mentioned in the help documentation.A grid dataset is always stored as 32 bit (either signed, unsigned, or floating point), but ArcGIS shows it above as being the most appropriate bit depth with regard to the cell values it contains.
