Passed EAOA_2024 exam, How to download Certificate and access digital badge?
1487
20
03-13-2024 05:35 PM
Ankitkhanna
New Contributor III
Hello,
I just got results for my ArcGIS Online Administration Associate 2024 (EAOA_2024) exam.I want to download the certificate and access digital badge, to do so I followed instructions at Manage your cert page [https://www.esri.com/training/certification-manage/]
  • Logged into CertMetrics, I can see my result there, but there is no option to download certificate, I can only Notice of Exam result which just mentioned about PASS result.
  • There is an option to access digital badge from Credly, but once I login to Credly I don't see any ESRI cert.
Anyone has any ideas on how to access certificate and digital badge?
Thanks in advance,
Ankit
KatieSmith
Hi all, apologies for the delay. Yes, this is a known issue with Credly and the Esri Technical Certification team is actively trying to resolve it. So sorry for the disruption this is causing - I'm sure you're all excited to share your badges and certificates.
Katie Smith | Principal Marketing Communications Specialist | Training Services
JohnPlunkett
Hi @KatieSmith sorry to keep on this thread - I am facing the same issue as well. - Passed the exam - but no option to download.,
Any assistance would be greatly appreciated
Thanks
Ankitkhanna
New Contributor III
Hi @JohnPlunkett, login to credly via CertMetrics, you should be able to download cert and badge from there.
Cheers, Ankit
KatieSmith
Hi @JohnPlunkett, if @Ankitkhanna's workflow above doesn't work for you, please reach out to the Esri Technical Certification team at https://www.esri.com/training/certification/contact/
JohnPlunkett
ok Ill send through a contact via the form.
JohnPlunkett
Hi Katie - I figured it all out - got it sorted - was clicking in the wrong place 🙂
KatieSmith
Glad you got the issue solved. Congratulations on passing the exam! 😊
DasheEbra
Occasional Contributor II
Hey @Ankitkhanna congratulations, the results and badges just issued from Esri.
cheers
Ankitkhanna
New Contributor III
Hi @DasheEbra Thanks! I can see certification record in my esri training records now.
Certificate and badge is still not available, which I know ESRI cert team is working with certmetrics and credly to resolve.
Kristofer
New Contributor III
Hi @DasheEbra ,
I'm still experiencing the same issue; the certificate and badge are still unavailable for me as well.
Kristofer
