I just got results for my ArcGIS Online Administration Associate 2024 (EAOA_2024) exam.I want to download the certificate and access digital badge, to do so I followed instructions at Manage your cert page [https://www.esri.com/training/certification-manage/]
Anyone has any ideas on how to access certificate and digital badge?
Thanks in advance,
Ankit
Hi all, apologies for the delay. Yes, this is a known issue with Credly and the Esri Technical Certification team is actively trying to resolve it. So sorry for the disruption this is causing - I'm sure you're all excited to share your badges and certificates.
Hi @KatieSmith sorry to keep on this thread - I am facing the same issue as well. - Passed the exam - but no option to download.,
Any assistance would be greatly appreciated
Hi @JohnPlunkett, login to credly via CertMetrics, you should be able to download cert and badge from there.
Cheers, Ankit
Hi @JohnPlunkett, if @Ankitkhanna's workflow above doesn't work for you, please reach out to the Esri Technical Certification team at https://www.esri.com/training/certification/contact/
ok Ill send through a contact via the form.
Hi Katie - I figured it all out - got it sorted - was clicking in the wrong place 🙂
Glad you got the issue solved. Congratulations on passing the exam! 😊
Hey @Ankitkhanna congratulations, the results and badges just issued from Esri.
cheers
Hi @DasheEbra Thanks! I can see certification record in my esri training records now.
Certificate and badge is still not available, which I know ESRI cert team is working with certmetrics and credly to resolve.
Hi @DasheEbra ,
I'm still experiencing the same issue; the certificate and badge are still unavailable for me as well.
Kristofer
