Passed EAOA_2024 exam, How to download Certificate and access digital badge?
4974
20
03-13-2024 05:35 PM
Ankitkhanna
Hello,
I just got results for my ArcGIS Online Administration Associate 2024 (EAOA_2024) exam.I want to download the certificate and access digital badge, to do so I followed instructions at Manage your cert page [https://www.esri.com/training/certification-manage/]
  • Logged into CertMetrics, I can see my result there, but there is no option to download certificate, I can only Notice of Exam result which just mentioned about PASS result.
  • There is an option to access digital badge from Credly, but once I login to Credly I don't see any ESRI cert.
Anyone has any ideas on how to access certificate and digital badge?
Thanks in advance,
Ankit
KatieSmith
Esri Alum
Hi all, apologies for the delay. Yes, this is a known issue with Credly and the Esri Technical Certification team is actively trying to resolve it. So sorry for the disruption this is causing - I'm sure you're all excited to share your badges and certificates.
Katie Smith | Principal Marketing Communications Specialist | Training Services
JohnPlunkett
Hi @KatieSmith sorry to keep on this thread - I am facing the same issue as well. - Passed the exam - but no option to download.,
Any assistance would be greatly appreciated
Thanks
Ankitkhanna
Hi @JohnPlunkett, login to credly via CertMetrics, you should be able to download cert and badge from there.
Cheers, Ankit
KatieSmith
Esri Alum
Hi @JohnPlunkett, if @Ankitkhanna's workflow above doesn't work for you, please reach out to the Esri Technical Certification team at https://www.esri.com/training/certification/contact/
JohnPlunkett
ok Ill send through a contact via the form.
JohnPlunkett
Hi Katie - I figured it all out - got it sorted - was clicking in the wrong place 🙂
KatieSmith
Esri Alum
Glad you got the issue solved. Congratulations on passing the exam! 😊
DasheEbra
Hey @Ankitkhanna congratulations, the results and badges just issued from Esri.
cheers
Ankitkhanna
Hi @DasheEbra Thanks! I can see certification record in my esri training records now.
Certificate and badge is still not available, which I know ESRI cert team is working with certmetrics and credly to resolve.
Kristofer
Hi @DasheEbra ,
I'm still experiencing the same issue; the certificate and badge are still unavailable for me as well.
Kristofer
